BT.com
Wishlist
Axis P3364-VE 6mm - Network camera - dome - outdoor
Axis P3364-VE 6mm - Network camera...
£762.99
£762.99
Add to wishlist
Delivery
Standard 1-3 working days
The AXIS P3364-VE is a 1-megapixel day and night fixed dome network camera that offers superb video performance. It delivers 30 fps in all resolutions up to HDTV 720p/1MP. The camera also supports digital pan/tilt/zoom, allowing a view area cropped from the full view to be streamed for viewing or recording. This can be used to minimize the bit rate and storage needs by optimizing the fixed viewing angle after installation, or by allowing pan, tilt and digital zoom in the view.
AXIS P3364-VE integrates Axis' Lightfinder technology. The outstanding light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components. The camera also supports P-Iris control, allowing the camera to precisely control the position of the iris. The iris opening is optimized for depth of field, lens resolution and light inlet, resulting in superb image quality with optimal sharpness.
AXIS P3364-VE 6mm - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
Audio
Yes: two-way audio capability
17.8 cm x 17.8 cm x 12.3 cm
1.5 kg
White
Wired
Camera
Colour - Day&Night
Optical Zoom
2.4 x
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.1 lux - colour - F1.2 , 0.02 lux - B&W - F1.2
Focal Length Control
Vari-focal
Focal Length
2.5 mm - 6 mm
Lens Iris
F/1.2
Panning Range (degree)
360
Tilting Range (degree)
170
Ethernet 10Base-T/100Base-TX
1 - network cable - 5 m
Voltage
PoE
Backlight compensation, manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, infrared cut filter, Privacy Mask Function, P-Iris control, text stamp, Video Motion Detection Technology, tamper-detection, Lightfinder technology, password protection
3 years warranty
Environmental Parameters (operating)
-40 °C - 55 °C; 10 - 100% relative humidity
Audio Support
Wired
17.8 cm
17.8 cm
12.3 cm
1.5 kg
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
1280 x 960
Exposure Range
2 sec - 1/24500 sec
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3"
Lens Construction
Vari-focal
Optical Zoom
2.4 x
Focal Length
2.5 mm - 6 mm
Lens Iris
F/1.2
Horizontal Field of View (degree)
49 - 105
Panning
Range (degree)
360
Titling
Range (degree)
170
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Mounting bracket, smoked dome cover
1 x network cable - 5 m
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78
White
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
-40 °C
55 °C
Relative Humidity (operating)
10 - 100%
Accessories
£4.95
£3.82
£11.95
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
£54.15
Scroll to top
