BT.com
Wishlist
Axis P3354 6mm-Network Camera-Dome-Tamper-Proof
Axis P3354 6mm-Network...
£578.17
£578.17
Add to wishlist
Delivery
Standard 1-3 working days
The AXIS P3354 is a 1-megapixel day and night fixed dome network camera that offers superb video performance. The camera also supports digital pan/tilt/zoom, allowing a view area cropped from the full view to be streamed for viewing or recording. This can be used to minimize the bit rate and storage needs by optimizing the fixed viewing angle after installation, or by allowing pan, tilt and digital zoom in the view.
AXIS P3354 integrates Axis' Lightfinder technology. The outstanding light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components. The camera also supports P-Iris control, allowing the camera to precisely control the position of the iris. The iris opening is optimized for depth of field, lens resolution and light inlet, resulting in superb image quality with optimal sharpness.
AXIS P3354 6mm - network surveillance camera
Network surveillance camera - fixed dome - tamper-proof
14.8 cm x 14.8 cm x 9.6 cm
430 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.1 lux - colour - F1.2 , 0.02 lux - B&W - F1.2
Focal Length Control
Vari-focal
Focal Length
2.5 mm - 6 mm
Lens Iris
F/1.2
Panning Range (degree)
360
Tilting Range (degree)
170
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Motion sensor, backlight compensation, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), SDHC-card slot, ONVIF support, infrared cut filter, Privacy Mask Function, P-Iris control, text stamp, Video Motion Detection Technology, tamper-detection, Lightfinder technology, digital PTZ function
3 years warranty
Environmental Parameters (operating)
0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Wired
14.8 cm
14.8 cm
9.6 cm
430 g
Camera
Colour - Day&Night - fixed dome - tamper-proof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 960
Exposure Range
2 sec - 1/29500 sec
RAM
256 MB
Flash Memory
128 MB
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Vari-focal
Focal Length
2.5 mm - 6 mm
Lens Iris
F/1.2
Horizontal Field of View (degree)
49 - 105
Panning
Range (degree)
360
Titling
Range (degree)
170
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP, SSL, QOS
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Smoked dome cover
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78
White
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
