BT.com
Wishlist
AXIS P1435-LE Network Surveillance Camera
Delivery
Standard 1-3 working days
AXIS P1435-LE network camera ensures compact and cost-effective HDTV surveillance for any light condition. With features such as Lightfinder and WDR, the bullet-style AXIS P1435-LE provides excellent image quality in HDTV 1080p resolution, even in complex light conditions. In addition, the camera supports pixel counter, remote zoom and focus, as well as P-Iris control. The day and night camera is ideal for 24/7 video surveillance, in exposed outdoor areas such as parking lots and service stations, and for general indoor surveillance purposes wherever a compact camera is needed.
AXIS P1435-LE - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
13.2 cm x 26 cm x 13.2 cm
800 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate
60 frames per second
Video Modes
1080/60p
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.12 lux - colour - F1.4 , 0.02 lux - B&W - F1.4 , 0 lux - infrared LEDs on
Focal Length Control
Vari-focal
Focal Length
3 mm - 10.5 mm
Focus Adjustment
Automatic
Lens Iris
F/1.4 - auto iris (P-Iris)
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Manual white balance, backlight compensation, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, infrared cut filter, Privacy Mask Function, Video Motion Detection Technology, digital PTZ function, Text Caption Overlay, password protection, OptimizedIR, Zipstream technology
3 years warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 10 - 100% relative humidity
Wired
13.2 cm
26 cm
13.2 cm
800 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080/60p
Exposure Range
2 sec - 1/66500 sec
Infrared LEDs
Infrared Distance
30 m
Video Capture
1920 x 1080 @ 60 fps , 1920 x 1080 @ 50 fps , 1920 x 1080 @ 30 fps , 1920 x 1080 @ 25 fps
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
Vari-focal
Focal Length
3 mm - 10.5 mm
Lens Iris
F/1.4 auto iris (P-Iris)
Focus Adjustment
Automatic
Horizontal Field of View (degree)
35 - 95
Vertical Field of View (degree)
20 - 51
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Mounting bracket
EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-6, IP66, IEC 60068-2-1, IEC 60068-2-2, EN 50121-4, IEC 62236-4, VCCI Class B, KN24, RCM, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B, AS/NZS CISPR 22 Class B
Power Requirements
PoE
11 Watt
Limited warranty - 3 years
-30 °C
60 °C
Relative Humidity (operating)
10 - 100%
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
