BT.com
Wishlist
Axis P1425-LE Network Surveillance Camera
Delivery
Standard Due date unavailable
AXIS P1425-LE is a compact, outdoor-ready bullet-style camera with built-in IR. This day and night camera is ideal for continuous video surveillance, in exposed outdoor areas such as parking lots, service stations and for general indoor surveillance purposes where a compact camera is needed.
AXIS P1425-LE Network Camera - network surveillance camera
Network surveillance camera - fixed - outdoor
Camera Mount Type
Wall mount
9 cm x 26 cm x 9 cm
788 g
Wired
Camera
Colour - Day&Night
Optical Zoom
3.5 x
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/2.8" - 2 MP
Minimum Illumination
0.25 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
Focal Length Control
Vari-focal
Focal Length
3 mm - 10.5 mm
Focus Adjustment
Automatic
Lens Iris
F/1.6
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Exposure compensation, backlight compensation, sharpness control, white balance, colour control, brightness control, Wide Dynamic Range (WDR), Privacy Mask Function, digital PTZ function
3 years warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Camera Mount Type
Wall mount
Wired
9 cm
26 cm
9 cm
788 g
Camera
Colour - Day&Night - fixed - outdoor
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Exposure Range
1/37000 sec - 2 sec
Video Capture
1920 x 1080 @ 30 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
2 MP CMOS 1/2.8"
Lens Construction
Vari-focal
Optical Zoom
3.5 x
Focal Length
3 mm - 10.5 mm
Lens Iris
F/1.6
Focus Adjustment
Automatic
Horizontal Field of View (degree)
33 - 92
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Mounting bracket, sunshield
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, IEC 60529 IP66, EN 61000-6-1, ICES-003 Class A, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, VCCI Class A, KN24, AS/NZS CISPR 22, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
Accessories
£4.95
£3.84
£12.04
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.56
Scroll to top
