BT.com
Wishlist
Axis Network Camera - Network Surveillance Camera
Axis Network Camera - Network...
£836.25
£836.25
Add to wishlist
Delivery
Standard Due date unavailable
AXIS Q3505-V is a high-performance, vandal-resistant fixed dome for high-security applications indoors. The camera is available with wide or telephoto lens. The camera delivers HDTV 1080p video at up to 60 frames per second, providing smooth video even when capturing fast movements.
The camera's Wide Dynamic Range (WDR) – Forensic Capture capability provides perfectly balanced video quality in scenes with strong variations in light, while the Lightfinder technology enables outstanding image usability in poor light. The camera can seamlessly transition between handling WDR and low-light conditions. AXIS Q3505-V also supports Axis’ Electronic Image Stabilization (EIS), which greatly improves video quality in situations where the camera is subject to vibration.
Furthermore, the camera supports barrel distortion correction and includes optical zoom that can be used when monitoring a scene. When using the optical zoom for monitoring, an operator can zoom in on an object, or the camera can zoom in automatically when the Gatekeeper functionality is applied.
AXIS Q3505-V Network Camera - network surveillance camera
Network surveillance camera - fixed dome - dustproof / waterproof / vandal-proof
Audio
Yes: two-way audio capability
16.2 cm x 16.2 cm x 11.6 cm
1.2 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
2.4 x
Max Resolution
1920 x 1080
Frame Rate
Optical Sensor Type
CMOS - 1/2.8" - 2.3 MP
Minimum Illumination
0.56 lux - colour - F1.6 , 0.11 lux - B&W - F1.6
Focal Length Control
Vari-focal
Focal Length
9 mm - 22 mm
Lens Iris
F/1.6 - auto iris (P-Iris)
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, manual exposure, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Privacy Mask Function, Electronic Image Stabilizer (EIS), text stamp, Video Motion Detection Technology, Lightfinder technology, active tampering alarm, digital PTZ function, ONVIF V2.2 (Profile S) support, password protection, microSD/SDHC/SDXC Memory Card slot, shock detection, Audio Detection
3 years warranty
Environmental Parameters (operating)
-10 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Audio Support
Wired
16.2 cm
16.2 cm
11.6 cm
1.2 kg
Camera
Colour - Day&Night - fixed dome - dustproof / waterproof / vandal-proof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Digital Zoom
2
Exposure Range
2 sec - 1/142850 sec
Video Capture
1920 x 1080 @ 60 fps
RAM
512 MB
Flash Memory
128 MB
Image Sensor
2.3 MP CMOS 1/2.8"
Lens Construction
Vari-focal
Optical Zoom
2.4 x
Focal Length
9 mm - 22 mm
Lens Iris
F/1.6 auto iris (P-Iris)
Horizontal Field of View (degree)
16 - 33
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS
Ports
LAN/power - RJ-45 , Audio line-in/microphone - 3.5 mm jack , Audio line out - 3.5 mm jack
C-Tick, CISPR 22 Class B, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-6, IEC 60529 IP52, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, AS/NZS, IEC 60068-2-52, IEC 62262 IK10, IEC 60068-2-60, EN 50121-4, IEC 62236-4, VCCI Class B, KN24, IEC 61000-6-1:2005, IEC 61000-6-2:2005, KCC KN22 Class B
Power Requirements
PoE
5.5 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
-10 °C
50 °C
Relative Humidity (operating)
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
£50.74
Scroll to top
