BT.com
Wishlist
Axis M5014 PTZ Dome Network Camera
£488.92
10 in stock
£488.92
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M5014 PTZ Dome Network Camera is a palm-sized, HDTV 720p pan/tilt/zoom camera that is affordably priced for remote and discreet monitoring of indoor areas such as stores, banks, hotels, office lobbies, restaurants and warehouses.
AXIS M5014 PTZ Dome Network Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - dustproof / waterproof
Audio
Yes: built-in microphone
Camera Mount Type
Ceiling mount
13 cm x 13 cm x 5.6 cm
330 g
Wired
Camera
Max Resolution
1280 x 720
Frame Rate
30 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1.4 lux - colour - F1.8
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/1.8
Panning Range (degree)
180
Tilting Range (degree)
90
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Motion sensor, backlight compensation, sharpness control, white balance, colour control, alarm function, progressive scanning, brightness control, Power over Ethernet, ONVIF support
1 year warranty
Environmental Parameters (operating)
0 °C - 45 °C; 10 - 85% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Ceiling mount
Wired
13 cm
13 cm
5.6 cm
330 g
Camera
Colour - pan / tilt / zoom - dustproof / waterproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Digital Zoom
3
Exposure Range
1/6 sec - 1/25000 sec
Video Capture
1280 x 720 @ 30 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/1.8
Horizontal Field of View (degree)
60
Panning
Range (degree)
180
Speed (degree/sec)
Up to 100
Titling
Range (degree)
90
Speed (degree/sec)
Up to 100
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP, SSL, QOS
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
C-Tick, VCCI Class B ITE, EN55024, EN55022 Class A, CISPR 22, EN 61000-6-1, FCC Part 15 B, ICES-003 Class A, EN 61000-6-2, EN 60950-1, KCC Class A
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 1 year
45 °C
Relative Humidity (operating)
Other bundles
£488.92
Kingston Gold microSD Card - Save 10%
Save £2.49
£502.82
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
