BT.com
Wishlist
Axis M3106-LVE Network Surveillance Camera
Axis M3106-LVE Network Surveillance...
£465.08
£465.08
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M3106-LVE is a flexible mini dome that gives you built-in IR illumination and Quad HD video quality at an attractive price. This outstanding product, it's suitable for outdoor use and perfect at the back entrance of a store, restaurant or hotel, for instance.
AXIS M3106-LVE - network surveillance camera
Network surveillance camera - fixed dome - dustproof / waterproof / tamper-proof
10.1 cm x 10.1 cm x 9.4 cm
370 g
Wired
Camera
Colour - Day&Night
Max Resolution
2688 x 1520
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3.6"
Focal Length
2.4 mm
Lens Mounting
M12 mount
Lens Iris
F/2.2 - fixed iris
Panning Range (degree)
180
Tilting Range (degree)
0 to 60
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Virtual Pan/Tilt/Zoom, digital PTZ function
3 years warranty
Environmental Parameters (operating)
-30 °C - 50 °C
Wired
10.1 cm
10.1 cm
9.4 cm
370 g
Camera
Colour - Day&Night - fixed dome - dustproof / waterproof / tamper-proof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
2688 x 1520
Exposure Range
1/5 sec - 1/32000 sec
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/3.6"
Lens Construction
M12 mount
Focal Length
2.4 mm
Lens Iris
F/2.2 fixed iris
Horizontal Field of View (degree)
130
Vertical Field of View (degree)
7.3
Panning
Range (degree)
180
Titling
Range (degree)
0 to 60
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
Power Requirements
PoE
4.6 Watt
Limited warranty - 3 years
-30 °C
50 °C
Scroll to top
