BT.com
Wishlist
Axis M3106-L Mini Network Surveillance Camera
Axis M3106-L Mini Network...
£414.93
17 in stock
£414.93
Add to wishlist
Delivery
Standard 1-3 working days
  • Built-in IR illumination
  • 4 MP / Quad HD video quality
  • Axis’ Zipstream technology
  • Supports video analytics
  • Discreet and flexible
  • Fast, easy, cost-effective installation
AXIS M3106-L is a flexible mini dome that gives you built-in IR illumination and Quad HD video quality at an attractive price. Our best-in-class product, it’s perfect at the back entrance of a store or hotel, for instance.
More light – or less?
With its built-in IR illumination AXIS M3106-L is ideal for situations where it’s sometimes dark or the lighting can be poor. Its innovative flat-faced design suppresses light reflections to maximize image usability when recording in the dark. AXIS M3106-L also offers Wide Dynamic Range (WDR) for excellent detail when light levels vary greatly, for example, at entrances with bright daylight outside and dimmer light inside.
Axis quality at an attractive price
AXIS M3106-L gives you sharp Quad HD image quality and a field of view of up to 130°. It features Axis’ Zipstream technology, which greatly reduces storage and bandwidth needs, while capturing important details in full image quality. AXIS M3106-L also supports video analytics such as Video Motion Detection and Active tampering alarm. Thanks to the AXIS Camera Application Platform, you can also choose to install AXIS Cross Line Detection, and AXIS Digital Autotracking, as well as third-party analytics solutions such as people counting.
Fits in anywhere
Small and flexible, AXIS M3106-L can be mounted on walls or ceiling as you prefer. Its smart design makes it easy to repaint to fit into any environment. And a long list of accessories, including black casing and various mounting kits, means it can be put up just about anywhere.
AXIS M3106-L - network surveillance camera
Network surveillance camera - fixed - dustproof / waterproof
10 cm x 10 cm x 8.5 cm
350 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
2688 x 1520
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3"
Lens Mounting
M12 mount
Lens Iris
F/2.2 - fixed iris
Panning Range (degree)
-180 to +180
Tilting Range (degree)
0 to 60
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, digital image rotation, white balance, colour control, brightness control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Privacy Mask Function, Virtual Pan/Tilt/Zoom, active tampering alarm, digital PTZ function, Text Caption Overlay, auto tracking, Edge Storage, video analytics, Zipstream technology, cross line detection, image overlay, exposure control, Pixel Counter Support, infrared-cut filter
3 years warranty
Environmental Parameters (operating)
0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Wired
10 cm
10 cm
8.5 cm
350 g
Camera
Colour - Day&Night - fixed - dustproof / waterproof
Digital Video Format
MJPEG, H.264, MPEG-4 AVC
Max Digital Video Resolution
2688 x 1520
Exposure Range
1/5 sec - 1/31500 sec
Infrared Distance
15 m
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/3"
Lens Construction
M12 mount
Lens Iris
F/2.2 fixed iris
Horizontal Field of View (degree)
130
Vertical Field of View (degree)
73
Panning
Range (degree)
-180 to +180
Titling
Range (degree)
0 to 60
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Torx L-key
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
White
Power Requirements
PoE
Software Included
Windows decoder 1-user licence
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
Scroll to top
