BT.com
Wishlist
Axis M3105-LVE Network Surveillance Camera
Axis M3105-LVE Network Surveillance...
£366.00
£366.00
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M3105-LVE is a flexible mini dome that gives you built-in IR illumination and HDTV 1080p video quality at an attractive price. It’s suitable for outdoor use and perfect at the back entrance of a store, restaurant or hotel, for instance.
With its built-in IR illumination AXIS M3105-LVE is ideal for situations where it’s sometimes dark or the lighting can be poor. Its innovative flat-faced design suppresses light reflections to maximize image usability when recording in the dark. AXIS M3105-LVE also offers Wide Dynamic Range (WDR) - Forensic Capture for excellent detail when light levels vary greatly, for example at entrances with bright daylight outside and dimmer light inside.
AXIS M3105-LVE - network surveillance camera
Network surveillance camera - fixed - outdoor
10.1 cm x 10.1 cm x 9.4 cm
380 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.2 lux - colour - F2.0 - 50 IRE , 0.04 lux - B&W - F2.0 - 50 IRE , 0 lux - IR
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
180
Tilting Range (degree)
0 to 60
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, infrared cut filter, Privacy Mask Function, dual video stream, active tampering alarm, digital PTZ function, Event Notification, Text Caption Overlay, password protection, auto tracking, Edge Storage, Variable Bitrate (VBR), video analytics, Zipstream technology, cross line detection, Forensic Capture (115 dB), image overlay
3 years warranty
Environmental Parameters (operating)
-30 °C - 50 °C
Wired
10.1 cm
10.1 cm
9.4 cm
380 g
Camera
Colour - Day&Night - fixed - outdoor
Digital Video Format
MJPEG, H.264, MPEG-4 AVC
Max Digital Video Resolution
1920 x 1080
Exposure Range
2 sec - 1/66500 sec
Infrared Distance
15 m
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
M12 mount
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
115
Vertical Field of View (degree)
64
Panning
Range (degree)
180
Titling
Range (degree)
0 to 60
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Connector cover, torx L-key
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP66, IEC 62262 IK08
White
Power Requirements
PoE
4.2 Watt
Software Included
Windows decoder 1-user licence
Limited warranty - 3 years
-30 °C
50 °C
Scroll to top
