BT.com
Wishlist
Axis M3105-L Network Surveillance Camera
Axis M3105-L Network Surveillance...
£315.88
£315.88
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M3105-L is an affordable, discreet fixed mini dome with a flat-faced design that suppresses reflections. Using WDR technology and IR illumination, it provides compact HDTV surveillance even in challenging light conditions or total darkness. The smart design allows for easy repainting, or using the optional black accessory casing to blend the camera into its environment. Axis' Zipstream technology reduces bandwidth and storage requirements. A variety of accessories are available for flexible and easy installation.
AXIS M3105-L - network surveillance camera
Network surveillance camera - fixed - dustproof / waterproof
10 cm x 10 cm x 8.5 cm
360 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.2 lux - colour - F2.0 - 50 IRE , 0.04 lux - B&W - F2.0 - 50 IRE , 0 lux - IR
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
-180 to +180
Tilting Range (degree)
0 to 60
Ethernet 10Base-T/100Base-TX
Voltage
PoE Plus
Sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, infrared cut filter, Privacy Mask Function, dual video stream, active tampering alarm, digital PTZ function, Event Notification, Text Caption Overlay, password protection, auto tracking, Edge Storage, Variable Bitrate (VBR), video analytics, Zipstream technology, cross line detection, Forensic Capture (115 dB), image overlay
3 years warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Wired
10 cm
10 cm
8.5 cm
360 g
Camera
Colour - Day&Night - fixed - dustproof / waterproof
Digital Video Format
MJPEG, H.264, MPEG-4 AVC
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Exposure Range
2 sec - 1/66500 sec
Infrared Distance
15 m
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
M12 mount
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
115
Vertical Field of View (degree)
64
Panning
Range (degree)
-180 to +180
Titling
Range (degree)
0 to 60
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Torx L-key
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42
White
Power Requirements
PoE Plus
4.2 Watt
Software Included
Windows decoder 1-user licence
Limited warranty - 3 years
-30 °C
50 °C
Relative Humidity (operating)
Scroll to top
