BT.com
Wishlist
Axis M3045-V Network Surveillance Camera
Axis M3045-V Network Surveillance...
£266.91
29 in stock
£266.91
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M3045-V is a fuller featured affordable fixed mini dome surveillance camera. It features HDTV 1080p video quality and an HDMI output for live streaming to a public monitor. Offering excellent video quality, it's perfect for stores, hotels, schools, banks and offices.
AXIS M3045-V - network surveillance camera
Network surveillance camera - fixed dome - dustproof / waterproof / vandal-proof
10.1 cm x 10.1 cm x 5.6 cm
170 g
White
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate
60 frames per second
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3" - 2 MP
Minimum Illumination
0.25 lux F2.0 - 50 IRE
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
-177 to +177
Tilting Range (degree)
-69 to +69
HDMI, Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, sharpness control, white balance, progressive scanning, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Privacy Mask Function, text stamp, Video Motion Detection Technology, active tampering alarm, digital PTZ function, password protection, Variable Bitrate (VBR), Zipstream technology
3 years warranty
Environmental Parameters (operating)
0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
Wired
10.1 cm
10.1 cm
5.6 cm
170 g
Camera
Colour - fixed dome - dustproof / waterproof / vandal-proof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Exposure Range
1/5 sec - 1/32500 sec
RAM
512 MB
Flash Memory
256 MB
Image Sensor
2 MP CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
106
Vertical Field of View (degree)
59
Panning
Range (degree)
-177 to +177
Titling
Range (degree)
-69 to +69
Video
HDMI
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Ports
LAN/power - RJ-45 , HDMI
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
EN55024, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, IP42, IEC 62262 IK08, VCCI Class B, RCM, AS/NZS CISPR 22 Class B
White
Power Requirements
PoE
3 Watt
Limited warranty - 3 years
45 °C
Relative Humidity (operating)
Scroll to top
