BT.com
Wishlist
Axis M3027-PVE Network CCTV Camera
£609.56
20 in stock
£609.56
Add to wishlist
Delivery
Standard 1-3 working days
The AXIS M3027-PVE network camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views. The vandal resistant, outdoor-ready mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for installations indoors or outdoors at hotels, gas stations, boutiques, restaurants, schools and offices.
AXIS M3027-PVE offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and Motion JPEG can be sent simultaneously.
AXIS M3027-PVE Network Camera - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
13.2 cm x 13.2 cm x 7.3 cm
740 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Optical Sensor Type
CMOS - 1/3.2"
Minimum Illumination
0.3 lux - colour - F2.0 , 0.06 lux - B&W - F2.0
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
High PoE
Backlight compensation, manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, Privacy Mask Function, text stamp, Video Motion Detection Technology, tamper-detection, digital PTZ function, SDXC-card slot
1 year warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Wired
13.2 cm
13.2 cm
7.3 cm
740 g
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Exposure Range
2 sec - 1/24000 sec
RAM
512 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3.2"
Lens Construction
M12 mount
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
187 - 180
Vertical Field of View (degree)
180
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Supported Memory Cards
SDXC Memory Card
CISPR 22 Class B, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, FCC CFR47 Part 15 B, IEC 62262 IK10, VCCI Class B, KN22, KN24
White
Power Requirements
High PoE
4.5 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.63
£50.74
Scroll to top
