BT.com
Wishlist
Axis M3026-VE Network Surveillance Camera
Axis M3026-VE Network Surveillance...
£539.67
£539.67
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M3026-VE Network Camera is a small and affordably priced, outdoor-ready and vandal-resistant fixed dome with 3-megapixel resolution, day/night functionality and enhanced capacity for video streaming and intelligent video applications. AXIS M3026-VE is ideal for installations at hotels, gas stations, restaurants, offices and schools, in areas that are sometimes dark and in need of a wide-angle, light-sensitive, day/night camera.
As with other cameras in the series, AXIS M3026-VE enables quick and easy installation. It can be mounted on walls or ceilings, and the camera direction can be easily adjusted. The camera supports Corridor Format for vertically oriented video streams that maximize coverage of areas such as along walls and aisles. It also comes focused at delivery, which shortens the installation time. A separate outdoor housing is not required as the camera is outdoor-ready with IP66 and NEMA 4X ratings, which ensure protection against dust, rain and snow. The camera also has an IK10 rating for resistance against impacts.
AXIS M3026-VE Network Camera - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
13.2 cm x 13.2 cm x 9.3 cm
740 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
2048 x 1536
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3.6" - 3 MP
Minimum Illumination
0.3 lux - colour - F2.0 , 0.06 lux - B&W - F2.0
Focal Length Control
Fixed focal
Focal Length
2 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
-175 to +175
Tilting Range (degree)
70
Ethernet 10Base-T/100Base-TX
1 - network cable - 2 m
Voltage
PoE Class 2
Backlight compensation, sharpness control, white balance, progressive scanning, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Privacy Mask Function, text stamp, Video Motion Detection Technology, active tampering alarm, digital PTZ function, ONVIF V2.2 (Profile S) support, password protection
1 year warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Wired
13.2 cm
13.2 cm
9.3 cm
740 g
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Exposure Range
2 sec - 1/30500 sec
RAM
512 MB
Flash Memory
128 MB
Image Sensor
3 MP CMOS 1/3.6"
Lens Construction
M12 mount - fixed focal
Focal Length
2 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
106
Panning
Range (degree)
-175 to +175
Titling
Range (degree)
70
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
1 x network cable - 2 m
C-Tick, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, IEC 62262 IK10, VCCI Class B, EN 50581, KN24, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B, AS/NZS CISPR 22 Class B
White
Power Requirements
PoE Class 2
4.5 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
Scroll to top
