BT.com
Wishlist
Axis M3025-VE Network Surveillance Camera
Axis M3025-VE Network Surveillance...
£456.91
£456.91
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M3025-VE network camera, which is part of the AXIS M30 series, is an affordably priced, vandal-resistant HDTV fixed mini dome for excellent video during day and night-time conditions in indoor or outdoor environments. It is ideal for installation inside or outside the entrance of a hotel, boutique, restaurant, office or school.
AXIS M3025-VE provides 2-megapixel, HDTV 1080p video. The outdoor-ready camera has IP66 and NEMA 4x ratings for protection against dust, rain and snow. The camera's IK 10 rating ensures resistance against impacts.
It also has day/night functionality with an automatically removable infrared-cut filter. When the filter is removed, the camera takes advantage of invisible near-infrared light from available light sources to produce good quality black and white images.
AXIS M3025-VE Network Camera - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
13.2 cm x 13.2 cm x 9.3 cm
740 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/2.7" - 2 MP
Minimum Illumination
0.8 lux - colour - F2.0 , 0.16 lux - B&W - F2.0
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
-175 to +175
Tilting Range (degree)
70
Ethernet 10Base-T/100Base-TX
1 - network cable - 2 m
Voltage
PoE Class 2
Backlight compensation, sharpness control, white balance, progressive scanning, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Privacy Mask Function, text stamp, Video Motion Detection Technology, active tampering alarm, digital PTZ function, ONVIF V2.2 (Profile S) support, password protection
1 year warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Wired
13.2 cm
13.2 cm
9.3 cm
740 g
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Exposure Range
1/6 sec - 1/8000 sec
RAM
256 MB
Flash Memory
128 MB
Image Sensor
2 MP CMOS 1/2.7"
Lens Construction
M12 mount - fixed focal
Focal Length
3.6 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
91
Panning
Range (degree)
-175 to +175
Titling
Range (degree)
70
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
1 x network cable - 2 m
C-Tick, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, IEC 62262 IK10, VCCI Class B, EN 50581, KN24, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B, AS/NZS CISPR 22 Class B
White
Power Requirements
PoE Class 2
3.2 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
Scroll to top
