BT.com
Wishlist
Axis M3007-PV Network Camera
Delivery
Standard Due date unavailable
The affordably priced AXIS M3007-PV Network Camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views of areas. The vandal- and dust-resistant indoor mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for retail stores, hotels, schools and offices.
AXIS M3007-PV offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection of corridors. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and motion JPEG can be sent simultaneously.
AXIS M3007-PV Network Camera - network surveillance camera
Network surveillance camera - fixed dome - dustproof / vandal-proof
6.5 cm x 13.1 cm x 13.1 cm
590 g
Wired
Camera
Max Resolution
2592 x 1944
Frame Rate
12 frames per second
Optical Sensor Type
CMOS - 1/3.2"
Minimum Illumination
0.6 lux F2.8
Focal Length
1.3 mm
Lens Mounting
M12 mount
Lens Iris
Fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Panorama Capture, digital PTZ function, password protection
1 year warranty
Environmental Parameters (operating)
0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
Wired
6.5 cm
13.1 cm
13.1 cm
590 g
Camera
Colour - fixed dome - dustproof / vandal-proof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
2592 x 1944
Exposure Range
1/24000 sec - 2 sec
0.6 lux F2.8
RAM
512 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3.2"
Lens Construction
M12 mount
Focal Length
1.3 mm
Lens Iris
Fixed iris
Horizontal Field of View (degree)
187
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Mounting kit
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
Power Requirements
PoE
4.6 Watt
Limited warranty - 1 year
45 °C
Relative Humidity (operating)
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
