BT.com
Wishlist
Axis M3007-P Network Surveillance Camera
Axis M3007-P Network Surveillance...
£456.91
19 in stock
£456.91
Add to wishlist
Delivery
Standard 1-3 working days
The AXIS M3007-P network camera is an ultra-discreet, 5-megapixel fixed mini dome that provides detailed, high quality panoramic views of areas as large as 650 m2 (7,000 sq. ft. ). The camera is ideal for retail stores, hotels, schools and offices.
AXIS M3007-P offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection of corridors. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and Motion JPEG can be sent simultaneously.
AXIS M3007-P can be mounted on a wall or ceiling. The camera comes focused at delivery, which shortens the installation time. It has a 2 m (6.6 ft. ) network cable attached and supports Power over Ethernet (IEEE 802.3af), which eliminates the need for power cables and reduces installation costs.
AXIS M3007-P Network Camera - network surveillance camera
Network surveillance camera - fixed dome
13.1 cm x 13.1 cm x 5.3 cm
570 g
White
Wired
Camera
Max Resolution
2592 x 1944
Frame Rate
12 frames per second
Optical Sensor Type
CMOS - 1/3.2" - 5 MP
Minimum Illumination
0.6 lux F2.8
Focal Length Control
Fixed focal
Focal Length
1.3 mm
Lens Mounting
M12 mount
Lens Iris
F/2.8 - fixed iris
Ethernet 10Base-T/100Base-TX
1 - network cable - 2 m
Voltage
PoE Class 2
Exposure compensation, backlight compensation, digital image rotation, white balance, progressive scanning, image mirror, Wide Dynamic Range (WDR), Privacy Mask Function, text stamp, smoke detector housing, digital PTZ function, ONVIF V2.2 (Profile S) support, password protection, 360° monitoring
1 year warranty
Environmental Parameters (operating)
0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
Wired
13.1 cm
13.1 cm
5.3 cm
570 g
Camera
Colour - fixed dome
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
2592 x 1944
Exposure Range
2 sec - 1/24000 sec
0.6 lux F2.8
RAM
512 MB
Flash Memory
128 MB
Image Sensor
5 MP CMOS 1/3.2"
Lens Construction
M12 mount - fixed focal
Focal Length
1.3 mm
Lens Iris
F/2.8 fixed iris
Horizontal Field of View (degree)
187
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Ports
LAN/power - RJ-45
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
1 x network cable - 2 m
C-Tick, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, VCCI Class B, KN24, KCC KN22 Class B, AS/NZS CISPR 22 Class B
White
Power Requirements
PoE Class 2
4.6 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year
45 °C
Relative Humidity (operating)
Scroll to top
