BT.com
Wishlist
Axis M3006-V Network Camera - Network camera - dome - dustproof /
Delivery
Standard Due date unavailable
AXIS M3006-V Network Camera delivers superb 3-megapixel video with a wide-angle view, and supports full frame rate HDTV 1080p. The affordably priced camera offers a cost-effective solution for retail stores, hotels, schools and offices with tight budgets for video surveillance.
Click on image to enlarge AXIS M3006-V provides a viewing angle of 134°, while its 3-megapixel resolution provides 50% more details than HDTV 1080p. With its wide horizontal and vertical angles of view, as well as its high resolution, the camera can offer complete coverage when installed near a corner of a store. A corner installation would also enable users to look into the shelves on either side of the camera.
AXIS M3006-V Network Camera - network surveillance camera
Network surveillance camera - fixed dome - dustproof / vandal-proof
8.5 cm x 13.1 cm x 13.1 cm
640 g
Wired
Camera
Max Resolution
2048 x 1536
Frame Rate
30 frames per second
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3.6"
Minimum Illumination
0.6 lux F2.8
Focal Length
1.6 mm
Lens Mounting
M12 mount
Lens Iris
Fixed iris
Panning Range (degree)
180
Tilting Range (degree)
45
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Virtual Pan/Tilt/Zoom, digital PTZ function
1 year warranty
Environmental Parameters (operating)
0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
Wired
8.5 cm
13.1 cm
13.1 cm
640 g
Camera
Colour - fixed dome - dustproof / vandal-proof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
2048 x 1536
Video Modes
1080p
Exposure Range
2 sec - 1/30500 sec
0.6 lux F2.8
Video Capture
2048 x 1536 @ 20 fps
RAM
512 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3.6"
Lens Construction
M12 mount
Focal Length
1.6 mm
Lens Iris
Fixed iris
Horizontal Field of View (degree)
134
Panning
Range (degree)
180
Titling
Range (degree)
45
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Mounting kit
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
Power Requirements
PoE
4.5 Watt
Limited warranty - 1 year
45 °C
Relative Humidity (operating)
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
