BT.com
Wishlist
Axis M2014-E Network Camera Colour Fixed Iris
Axis M2014-E Network Camera Colour...
£322.72
£322.72
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M2014-E is a high-performance, compact bullet-style network camera, designed for maximum flexibility and ease of installation. The camera's functional and compact form factor makes it perfect for installations in retail stores, boutiques, hotels and small offices. The camera has a unique design concept comprising a main unit and a separate camera unit, which allows these units to be mounted up to 8 meters (26 feet) apart, providing flexibility to place the camera unit in one place and the main unit elsewhere.
AXIS M2014-E offers a small-scale, convenient video management solution with its built-in micro-SDHC memory card slot for edge storage and support for AXIS camera companion. AXIS M2014-E supports intelligent video features such as motion detection, tampering alarm and I/O ports for connecting external devices. In addition, AXIS camera application platform support is also provided.
AXIS M2014-E Network Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - dustproof / waterproof
Wired
Camera
Max Resolution
1280 x 720
Frame Rate
30 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1 lux F2.0
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
DC 8 - 28 V / PoE
Backlight compensation, sharpness control, digital image rotation, white balance, auto exposure control, colour control, progressive scanning, brightness control, contrast control, e-mail alerts, image mirror, AXIS Video Hosting System (AVHS), Privacy Mask Function, Video Motion Detection Technology, active tampering alarm, ONVIF V2.2 (Profile S) support, password protection
1 year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Wired
Camera
Colour - fixed - outdoor - dustproof / waterproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Exposure Range
1/6 sec - 1/24500 sec
1 lux F2.0
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
81
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Mounting kit
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-27, IEC 60068-2-6, IP66, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, VCCI Class B, KN24, AS/NZS CISPR 22, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B
Power Requirements
DC 8 - 28 V / PoE
Software Included
Drivers & Utilities
Limited warranty - 1 year
-20 °C
50 °C
Relative Humidity (operating)
Accessories
£4.95
£3.78
£11.54
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.29
Scroll to top
