BT.com
Wishlist
Axis M1124 Network Camera Network Surveillance Camera
Axis M1124 Network Camera Network...
£328.78
32 in stock
£328.78
Add to wishlist
Delivery
Standard 1-3 working days
AXIS M1124 offers a professional and affordable fixed camera suitable for a wide range of video surveillance applications, such as for retail and banking as well as libraries and other office buildings. It can be used indoors, as well as in an outdoor housing.
AXIS M1124 Network Camera - network surveillance camera
Network surveillance camera - fixed
4.4 cm x 7 cm x 14.8 cm
200 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Video Modes
720p
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.25 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
Focal Length Control
Vari-focal
Focal Length
3 mm - 10.5 mm
Lens Mounting
CS-mount
Lens Iris
F/1.4 - auto iris (DC)
Ethernet 10Base-T/100Base-TX
Voltage
DC 8 - 28 V / PoE
Sharpness control, white balance, colour control, brightness control, contrast control, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Video Motion Detection Technology, active tampering alarm, digital PTZ function, LED indicator, password protection, IR Corrected lens, Variable Bitrate (VBR)
1 year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
Wired
4.4 cm
7 cm
14.8 cm
200 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Exposure Range
2 sec - 1/143000 sec
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
CS-mount - vari-focal
Focal Length
3 mm - 10.5 mm
Lens Iris
F/1.4 auto iris (DC)
Horizontal Field of View (degree)
32 - 91
Vertical Field of View (degree)
18 - 49
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Stand
C-Tick, EN 61000-3-2, EN 61000-3-3, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, EN 50121-4, VCCI Class A, EN 50581, KN24, KCC KN22, AS/NZS CISPR22:2004 Class A, EN 55024, EN 55022 Class A
White
Power Requirements
DC 8 - 28 V / PoE
Limited warranty - 1 year
-20 °C
50 °C
Relative Humidity (operating)
Accessories
£5.17
£3.90
£12.74
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.12
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.70
£57.14
Scroll to top
