BT.com
Wishlist
Axis M1114 HDTV
Delivery
Standard Due date unavailable
AXIS M1114 network camera with CS-mount, varifocal, DC-iris lens provides excellent image quality without motion blur using progressive scan at 30 frames per second in 1 megapixel / HDTV resolution. The cost-effective, compactly designed camera offers multiple H.264 and Motion JPEG streams that can be individually optimized for bandwidth and storage efficiency. It features Power over Ethernet support, digital PTZ functionality and a pixel counter to verify that the required pixel resolution is met. Intelligent video functionalities include video motion detection and active tampering alarm. AXIS M1114 is ideal for securing retail stores, malls, schools, banks and other office buildings, indoors as well as in an outdoor housing.
AXIS M1114 Network Camera - network surveillance camera
Network surveillance camera - fixed
6.1 cm x 9.4 cm x 4.3 cm
200 g
Wired
Camera
Max Resolution
1280 x 800
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0.6 lux F1.2
Focal Length Control
Vari-focal
Focal Length
2.8 mm - 8 mm
Lens Mounting
CS-mount
Lens Iris
Auto iris (DC)
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control
1 year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 20 - 80% relative humidity
Wired
6.1 cm
9.4 cm
4.3 cm
200 g
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 800
Exposure Range
1/24500 sec - 1/6 sec
0.6 lux F1.2
Video Capture
1280 x 800 @ 30 fps
RAM
128 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
CS-mount - vari-focal
Focal Length
2.8 mm - 8 mm
Lens Iris
Auto iris (DC)
Horizontal Field of View (degree)
29 - 87
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, Bonjour, RTCP, IGMP
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 60950-1, EN 61000-6-3
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 1 year
-20 °C
50 °C
Relative Humidity (operating)
20 - 80%
Scroll to top
