BT.com
Wishlist
Axis M1054 Surveillance Kit  Network camera  colour fixed  POE
Axis M1054 Surveillance Kit...
£1,243.47
£1,243.47
Add to wishlist
Delivery
Standard Due date unavailable
AXIS M1054 network camera uses progressive scan technology providing full frame rate video in resolutions up to 1-megapixel including HDTV 720p. Multiple H.264 and Motion JPEG streams can be provided simultaneously individually optimized for different quality needs and bandwidth constraints.
The AXIS M1054 features an integrated PIR sensor for detecting movement even in the dark, and a white LED for illuminating the scene at an event. It additionally supports I/O ports for connecting external devices.
Designed for easy and flexible installation, AXIS M1054 can be powered either over Ethernet or by power supply. AXIS M1054 easily finds application in boutiques, restaurants, hotels and residences.
AXIS M1054 Surveillance Kit - network surveillance camera
Network surveillance camera - fixed
Packaged Quantity
4 (specifications are for single item)
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.9 cm x 4.1 cm x 9.5 cm
160 g
Wired
Camera
Max Resolution
1280 x 800
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1.2 lux F2.0
Focal Length
2.9 mm
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
DC 5 V / PoE
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, alarm function, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, built-in LED illuminator
1 year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Packaged Quantity
Audio Support
Wired
5.9 cm
4.1 cm
9.5 cm
160 g
United Kingdom
Camera
Colour - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 800
Exposure Range
1/24500 sec - 1/6 sec
1.2 lux F2.0
RAM
128 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.9 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
84
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, Bonjour, RTCP, IGMP
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, EN 60950-1
Power Requirements
DC 5 V / PoE
Power adapter - external
Software Included
Drivers & Utilities
Limited warranty - 1 year
Relative Humidity (operating)
Other bundles
Axis M1054 Surveillance Kit Network camera colour...
£1,243.47
Save on TP Link Smart Plug
Save £2.00
£1,267.44
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
