BT.com
Wishlist
Axis M1025 2MP Network CCTV Camera
£251.19
£251.19
Add to wishlist
Delivery
Standard Due date unavailable
AXIS M1025 delivers HDTV 1080p or 2-megapixel resolution in full frame rate, in multiple H.264 Motion and JPEG streams, individually optimized for different quality needs and bandwidth constraints. When connecting the camera via the HDMI output (Micro), the live view streaming can be viewed on a public monitor at HDTV 720p. With a wide horizontal field of view of 94 degrees, AXIS M1025 also offers a fixed lens with adjustable focus.
AXIS M1025 Network Camera - network surveillance camera
Network surveillance camera - fixed
5.9 cm x 4.1 cm x 9.5 cm
144 g
White
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.7" - 2 MP
Minimum Illumination
1.5 lux F2.8
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Focus Adjustment
Manual
Lens Iris
F/2.8 - fixed iris
HDMI, Ethernet 10Base-T/100Base-TX
Voltage
DC 4.9 - 5.1 V / PoE Plus
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), Privacy Mask Function, text stamp, active tampering alarm, digital PTZ function, notification picture to FTP, ONVIF V2.2 (Profile S) support, password protection
1 year warranty
Environmental Parameters (operating)
0 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Wired
5.9 cm
4.1 cm
9.5 cm
144 g
United Kingdom
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, H.264, AVC
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Exposure Range
1/6 sec - 1/8000 sec
1.5 lux F2.8
RAM
256 MB
Flash Memory
128 MB
Image Sensor
2 MP CMOS 1/2.7"
Lens Construction
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/2.8 fixed iris
Focus Adjustment
Manual
Horizontal Field of View (degree)
94.3
Vertical Field of View (degree)
50.2
Video
HDMI
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Ports
LAN/power - RJ-45 , HDMI output
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Stand
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, IEC 60950-1, EN 60950-1, KCC Class B, VCCI Class B
White
Power Requirements
Power adapter - external 2.4 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year
50 °C
Relative Humidity (operating)
Other bundles
£251.19
Kingston Gold microSD Card - Save 10%
Save £2.49
£265.09
Accessories
£9.99
£5.98
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.99
£39.99
£54.98
£17.48
Scroll to top
