BT.com
Wishlist
Avocent SwitchView DVI - 1x4 USB DVI KVM Switch
Delivery
Standard Due date unavailable
Avocent SwitchView DVI and USB KVM Switch, 4-port with built-in USB 2.0 hub and audio device sharing. Avocent SwitchView DVI 4-port KVM switch easily manages two USB DVI computers from a single USB keyboard, mouse and DVI monitor. With video resolutions up to 1920x1200, the SwitchView DVI delivers crisp images for today's high-end displays. Also, share speakers and microphone between PCs. Includes an integrated USB hub.
Manage four USB DVI computers from a single USB keyboard, mouse and DVI monitor;
Integrated USB 2.0 hub for sharing USB peripherals/devices;
1920 x 1200 video resolution ideal for desktop graphical applications;
Support for high-end applications, including DVI monitor and flat panel;
Support for USB PCs, Mac G3/G4, Imac;
Multimedia support including speaker and microphone;
Auto scanning allows easy monitoring of attached computers;
Easily add computers without powering down the KVM switch or attached computers.
Avocent Switchview DVI - KVM / audio switch - 4 ports - desktop
KVM / audio switch - 4 ports - USB
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
25.4 cm x 11.7 cm x 4.3 cm
1.4 kg
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
Built-in Devices
USB Hub
4 x mini-USB 2.0 - Type B , 4 x DVI-D , 4 x headphones - mini-jack , 4 x microphone - mini-jack , 2 x USB 2.0 - Type A , 1 x DVI-D , 2 x USB 2.0 - Type A
External power adapter
EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B
25.4 cm
11.7 cm
4.3 cm
1.4 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great KVM but take care with DVI cable lengths and monitor resolutions
Reviewed by Ed on 16/10/2007
Great KVM with a March 2007 firmware update available from Avocent to handle MS/Logitech keyboards and mice for extra keys.
Comes with a UK power transformer.
Pros:
It handles high resolution DVI - 1680x1050 in my case.
Supports WinXP and Linux without troubles (haven't tried Solaris but it shouldn't be a problem)
Cons:
Take care with DVI cable lengths when running high resolutions. At 1680x1050 there is no signal using a 5m cable into the KVM and so you need a DVI signal booster.
The KVM doesn't come with any leads. These need to be puchased separately (whether using Avocent all-in-one leads or individual leads)
Scroll to top
