BT.com
Wishlist
Avocent SwitchView 1000 - 1x8 PS/2/USB KVM Switch
Avocent SwitchView 1000 - 1x8...
£307.83
£307.83
Add to wishlist
Delivery
Standard Due date unavailable
The cost-efficient SwitchView 1000 8-port KVM switch provides PS/2 or USB connectivity for users and target devices. This single user switch has an on-screen display (OSD) and supports a 2048 x 1536 high video resolution that is ideal for graphical applications. With a 1U high design, the compact SwitchView 1000 8-port switch does not compete for valuable rack space in SMB server rooms. Plus, this KVM rack solution is flash upgradeable for fast and easy updates. The SwitchView 1000 8-port switch password protection feature gives you the benefit of added security access to your business-critical servers.
Avocent Switchview 1000 - KVM switch - 8 ports - desktop
KVM switch - 8 ports - PS/2 - stackable
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display
41 cm x 16.5 cm x 4.5 cm
1.9 kg
KVM switch - 8 ports - stackable
Enclosure Type
Desktop - 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Units In A Stack
16
Max Resolution
2048 x 1536
On-Screen Display
8 x KVM - HD-15 , 1 x network stack device input - DB-15 , 1 x network stack device output - DB-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA - HD-15 , 2 x USB - Type A
External power adapter
UL, C-Tick, cUL, FCC
41 cm
16.5 cm
4.5 cm
1.9 kg
Scroll to top
