BT.com
Wishlist
Avocent HMX HMIQDHDD Computer Interface Module - Monitor/USB/Audio Extender
Avocent HMX HMIQDHDD Computer...
£848.66
£848.66
Add to wishlist
Delivery
Standard Due date unavailable
Extend digital and analog video, USB keyboard and mouse, USB media, and audio signals with the HMX 2050 extender. The HMX 2050 extender provides today's digital content creation professionals with high resolution video, rich color depth, uncompromised responsiveness, CD quality audio, and compatibility with a wide range of user interface devices - while mission critical servers are securely maintained and managed.
The Avocent HMX 2050 extender delivers uncompromised digital workstation extension across unlimited distances. Offering high quality crisp video and highly responsive mouse interaction, this network-based product also provides CD quality audio and seamless extension of USB mass storage devices. Media-intense applications such as video editing benefit from real-time user experience while mission critical media servers are securely maintained and managed. The HMX 2050 extension product consists of a transmitter that connects externally to each remote computer with dual DVI-D video connectors, and a receiver that connects at each user desk with dual DVI-I connectors.
The HMX 2050 extender provides access from dual video monitor workstations to user stations using point-to-point extension over the same IP connection. The high quality extension provided by the HMX 2050 product is ideal for users who need a rich media dual video display experience while using TCP/IP as the transport protocol. The solution operates within the boundaries of a typical IP network.
Avocent HMX HMIQDHDD Computer Interface Module - monitor/USB/audio extender
Monitor/USB/audio extender
External
Data Transfer Rate
1 Gbps
AC 120/230 V
12.7 cm x 20 cm x 2.8 cm
0.8 kg
HMX 2050 User Station
External
Wired
Data Transfer Rate
1 Gbps
Max Resolution
1920 x 1200 @ 60 Hz
128-bit encryption
1 x USB - Type A , 2 x DVI-I , 1 x audio ( output ) - mini jack , 1 x network - RJ-45
UL, cUL, FCC Part 15 A
External power adapter
AC 120/230 V
6 Watt
12.7 cm
20 cm
2.8 cm
0.8 kg
Avocent HMX 2050 User Station
Scroll to top
