BT.com
Wishlist
Avocent 4PORT PS/2 SWITCH WITH AUDIO CABLE SETS INCLUDED
Avocent 4PORT PS/2 SWITCH WITH...
£84.10
£84.10
Add to wishlist
Delivery
Standard Due date unavailable
You can connect and control your entire desktop with one of the industry's smallest, powerful and most versatile desktop KVM solutions. The SwitchView 100 series KVM switching solutions include four compact and affordably priced desktop KVM switches that support small office/ home office (SOHO) and desktop multimedia applications.
The SwitchView PS/2 switching series lets you access and control up to four PS/2-enabled multimedia computers using only one PS/2 keyboard and mouse and VGA monitor. The SwitchView 100 switches provide audio and microphone support. Cables are included with each switch.
Avocent SwitchView 100 Series Desktop KVM Switch - KVM / audio switch - 4 ports - desktop
KVM / audio switch - 4 ports - PS/2
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
7.2 cm x 16.4 cm x 2.6 cm
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
2048 x 1536
Status Indicators
Port status
4 x KVM - HD-15 , 4 x audio - mini-jack , 4 x microphone - mini-jack , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA - HD-15 , 1 x audio - mini-jack , 1 x microphone - mini-jack
4 x keyboard / mouse / video cable - 1.2 m , Audio cable kit
C-Tick, FCC
7.2 cm
16.4 cm
2.6 cm
2 years warranty
Service & Support Details
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent KVM
Reviewed by Anonymous on 18/07/2009
I bought this to replace a year old cheap 4 port Belkin unit which was touchy from day one, and refused to select the other three inputs, despite being thumped firmly on occasion.
It uses special cables which reduces cable mess, but doesn't let you reuse old ones, which is a shame as those supplied (4) are only a metre or so long, and is a stretch for my setup, so the longer Belkin ones have to go in the same pile of disgust as the old kvm.
The audio switching is supposed to be for speakers and mic, but I use it to switch front and rear speakers instead, and that works just fine.
I do not use either a wireless keyboard or mouse, so I cannot comment on performance with them
The switching for both video and audio works without any issues on my setup without any apparent loss of quality, and I would not hesitate to recommend this kvm.
5* Nice little KVM
Reviewed by Ben on 26/08/2010
Works nicely, wasn't expecting much from the audio switching but it's fine.
The cables supplied are of an adequate length if you put the unit on top of the computers you're switching between. You may need to get a 63P1 and two 63NW for each computer that need to be further than 1 metre from the unit. The keyboard switch command is scroll-lock scroll-lock [port number] so you don't need to physically press the buttons on the unit.
One downside is that mice don't work with the Belkin PS/2 to USB adapter (QL: 3BB3), although they does work with other cheaper adapters.
Scroll to top
