BT.com
Wishlist
Avaya Ethernet Routing Switch 3510GT
Delivery
Standard Due date unavailable
This standalone fanless unit supports silent operation in open environments and offers eight ports of 10/100/1000 with two SFP ports.
Avaya Ethernet Routing Switch 3510GT - switch - 8 ports - Managed
Switch - 8 ports - L3 - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x SFP
Performance
Switching capacity: 20 Gbps , Forwarding performance: 14.9 Mpps
Multiple Spanning Tree Protocol instances: 8 , ARP entries: 512
MAC Address Table Size
16000 entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 2, SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, SSH-2
Flow control, DHCP support, auto-negotiation, BOOTP support, ARP support, trunking, VLAN support, DiffServ support, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), IP Precedence, RADIUS support, fanless, LACP support, LLDP support, DHCP relay, SNMP trap, Energy Efficient Ethernet, Management Information Base (MIB), Neighbor Discovery Protocol (NDP), static routing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
22 cm x 20 cm x 4.45 cm
1.75 kg
Belgium, Austria, Finland, France, Germany, Netherlands, Norway, Sweden
Bundled Services
Enclosure Type
Desktop, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16000 entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP
Encryption Algorithm
RSA, SSL
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
1: 400 MHz
RAM
128 MB
Flash Memory
32 MB
2 x SFP (mini-GBIC) , 8 x 1000Base-T - RJ-45 , 1 x console - RJ-45 - management
Internal power supply
18 Watt
Rubber feet
MTBF
892,667 hours
Plug and Play, CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 60950, NOM, VCCI Class A ITE, IEC 60950, EN55024, EN55022 Class A, UL 60950, CB, MIC, ICES-003 Class A, AS/NZS 3548, RoHS, FCC Part 15 B Class A
22 cm
20 cm
4.45 cm
1.75 kg
Limited warranty - lifetime - response time: next business day , Technical support - consulting - software - 90 days , Technical support - lifetime
50 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
