BT.com
Wishlist
ATL Delta 700 Light Grey
£55.10
3 in stock
£55.10
Add to wishlist
Delivery
Standard 3-5 working days
The ATL Delta 700 is a two-line CLI Featurephone with 32 two-touch speed dial memories. Features include hands free, time break recall, LCD Display with time and date, standard headset port. The phone can be wall mounted and brackets are supplied accordingly.
ATL Delta 700 - corded phone with caller ID/call waiting
Corded phone with caller ID/call waiting
Multiline Operation Capability
2-line operation
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Transfer, Call Hold
Display
LCD display - monochrome
Body Colour
Light grey
2 years warranty
Corded phone
Body Colour
Light grey
Phone Features
Call Services
Caller ID Type
Caller ID/call waiting
Dialer Type
Keypad
Dialer Location
Base
Dialing Modes
Pulse, tone
2-line operation
Conference Call Capability
Speakerphone
Menu Operation
Indicators
Visual ringer light, line status indicator
Additional Functions
Call timer, built-in clock, built-in calendar
Phone Memory
One-Touch Dial Button Qty
3
Caller ID Memory
64 names & numbers
Display
Display Location
Base
Headset jack / RJ-11 , Data port
Placing / Mounting
Wall-mountable, table-top
2 x phone line cable
4 x battery - AA type
Included Qty
4
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Amazing Workhorse
Reviewed by Paul on 29/09/2014
I have owned one of these phones for over 9 years, and it's still going strong. It comes with two line cables allowing you to plug the phone into two standard BT sockets and have a line 1 and line 2.
I use my line 1 connection in my BT socket for normal PSTN calls, and my line 2 is connected to a LINKSYS PAP2-NA SIP converter which delivers a second line over SIP. This has worked exceptionally well for years, and with the helpful CLI display on the phone, I can see if I've missed calls.
The only negative points:
The headset works well, as does the Handsfree, but unfortunately you have to configure in SETTINGS whether you want to be able to use HANDSFREE or HEADSET, you can't easily switch between the two modes.
Unfortunately the Delta 700 is not very hearing aid friendly. Even at full volume, I struggle to hear speech through the handset or through the headset (even when using an induction headset). I am hard of hearing. If you are hard of hearing, avoid this handset!
Scroll to top
