BT.com
Wishlist
Aten 4 Port VGA Switch with Audio Black
Aten 4 Port VGA Switch with Audio...
£77.64
£77.64
Add to wishlist
Delivery
Standard Due date unavailable
The VS0401 4-port VGA switch with audio allows you to connect four audio/video source computers to a single monitor or projector with full audio and quickly switch between the devices for use.
VS0401 features built-in bi-directional RS-232 serial port for high-end system control, and advanced RS-232 control. With the ability to use high-end serial control devices via RS-232 commands allows the VS0401 to be controlled by secondary systems with advanced functions such as; port switching, auto switching, front panel pushbutton lock, and power on detection.
The VS0401 is perfect for the meeting room, media centers, class rooms, or any presentation environment requiring multiple audio/video sources to be accessed on a single display.
ATEN VanCryst VS0401 - video/audio switch - 4 ports - desktop
Video/audio switch - 4 ports
Enclosure Type
Desktop
Subtype
VGA / audio
Ports
4 x VGA / audio
20 cm x 7.61 cm x 4.4 cm
660 g
Enclosure Type
Desktop
Subtype
VGA / audio
Ports
4 x VGA / audio
Max Resolution
1920 x 1440
Max Video Bandwidth
300 MHz
Status Indicators
Power, select
4 x VGA input - HD-15 , 4 x audio input - mini-jack , 1 x management (RS-232) - DB-9 , 1 x VGA output - HD-15 , 1 x audio output - mini-jack , 1 x IrDA - mini-jack
External power adapter
0.55 Watt
Plug and Play, RoHS, DDC, WEEE
20 cm
7.61 cm
4.4 cm
660 g
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
