BT.com
Wishlist
Aten 2-port VGA Audio/Video Switch
£51.16
3 in stock
£51.16
Add to wishlist
Delivery
Standard 3-5 working days
The VS0201 2-port VGA switch with audio allows you to connect two audio/video source computers to a single monitor or projector with full audio and quickly switch between the devices for use.
VS0201 built-in bi-directional RS-232 serial port for high-end system control, and advanced RS-232 control. With the ability to use high-end serial control devices via RS-232 commands allows the VS0201 to be controlled by secondary systems with advanced functions such as; port switching, auto switching, front panel pushbutton lock, and power on detection.
The VS0201 is perfect for the meeting room, media centers, class rooms, or any presentation environment requiring multiple audio/video sources to be accessed on a single display.
ATEN VanCryst VS0201 - video/audio switch - 2 ports - desktop
Video/audio switch - 2 ports
Enclosure Type
Desktop
Subtype
VGA / audio
Ports
2 x VGA / audio
7.61 cm x 13 cm x 4.4 cm
450 g
Enclosure Type
Desktop
Subtype
VGA / audio
Ports
2 x VGA / audio
Max Resolution
1920 x 1440
Status Indicators
Power, select
2 x VGA input - HD-15 , 2 x audio input - mini-jack , 1 x management (RS-232) - DB-9 , 1 x VGA output - HD-15 , 1 x audio output - mini-jack , 1 x IrDA - mini-jack
External power adapter
0.55 Watt
RoHS, WEEE
7.61 cm
13 cm
4.4 cm
450 g
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
