BT.com
Wishlist
Asustor AS-1004T 4-Bay ARMADA Dual Core 512MB GbE USB3,0 NAS Diskless
Delivery
Standard Due date unavailable
AS10 series devices are equipped with fast processors, Gigabit Ethernet interfaces, and come with ASUSTOR's dedicated ADM operating system. They provide extra high read and write speeds. The AS10 devices also feature built-in encryption engines, allowing data to be completely protected from the moment it is first stored on the NAS. This means that you never have to worry about your confidential data falling into the wrong hands even if your hard disks become lost or stolen. The built-in hardware encryption engine also features high read and write speeds for encrypted data providing an optimal combination of file security and system performance. Moreover, the AS10 series devices boast the stylish diamond-plate finished cover, which makes it an elegant addition to any space, no matter if it is a family room, living room or office. And their sliding outer cover design allows it to be conveniently removed when needed. The inner hard disk rails and outer cover all use hand screws allowing for the simple installation of hard disks without any extra tools.
ASUSTOR AS1004T - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
32 TB
0 (installed) / 4 (max)
16.4 cm x 21.8 cm x 16.5 cm
1.5 kg
1 x Marvell ARMADA 385 1 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
8
AC 120/230 V
Storage Operating System
ASUSTOR Data Master (ADM) 2.5
UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
32 TB
16.4 cm
21.8 cm
16.5 cm
1.5 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, DDNS
Remote Management Protocol
HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Firewall protection, hardware encryption, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, iTunes server, Jumbo Frames support, SMS alert, e-mail server, UPnP Media Server, bandwidth control, IPv4 support, SNMP trap, cloud backup, SNMP support
Encryption Algorithm
256-bit AES
UPnP
Security DVR
8
Expansion Bays
4 (total) / 4 (free) x hot-swap - 3.5"
2 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Built-in cooling fan, UPS support
VCCI, C-Tick, BSMI, FCC
X external power adapter
AC 120/230 V
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
33 dB
Scroll to top
