BT.com
Wishlist
Asus Z97-K/USB 3.1 S1150 Intel Z97 DDR3 USB3.1 ATX
Asus Z97-K/USB 3.1 S1150 Intel Z97...
£113.83
£113.83
Add to wishlist
Delivery
Standard Due date unavailable
Proven quality, enduring trust with the latest 10Gbit/s USB 3.1 and M.2 transfer speed -- 2X faster than USB 3.0!
  • Ultra-fast 10Gb/s USB 3.1 built in to the board
  • ASUS Reversible USB 2.0-Any way up! The world's first reversible USB 2.0 on board.
  • Proven quality - 5X Protection. 1000+ compatible devices. 7000+ validation hours.
  • Speed up your system with lightning-fast 10Gb/s M.2
  • Fan Xpert 2+ - Ultimate cooling and quietness
  • Media-acclaimed UEFI BIOS with new EZ Tuning Wizard
  • ASUS HomeCloud - A digital PC hub perfect for sharing and home theater
ASUS Z97-K/USB3.1 - motherboard - ATX - LGA1150 Socket - Z97
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 2 x USB 3.0 + 1 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.), 3200 MHz (O.C.), 2250 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
512 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111GR
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 (x2 mode) , 2 x PCIe x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA, 1 x M.2 - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 1 x USB 2.0 , 1 x HDMI , 2 x USB 3.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x DVI-D , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.1
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, UEFI BIOS, DMI 2.7 support, ACPI 5.0 support, SMBIOS 2.8 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, ASUS TurboV EVO, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heatsink, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, anti-pop function, ASUS Crystal Sound 2, ASUS Fan Xpert 2+, USB 3.1 Boost, reversible USB 2.0 port
I/O back plate
2 x Serial ATA cable
Software Included
ASUS EZ Flash 2, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, ASUS HomeCloud, Antivirus (OEM version)
Plug and Play
30.5 cm
21.8 cm
Scroll to top
