BT.com
Wishlist
Asus Z87-PLUS S1150 Intel Z87 DDR3 ATX
Delivery
Standard Due date unavailable
Asus Z87-Plus High Performance Z87 chipset mainboard with mDP, HDMI, DVI and D-Sub Outputs.
The Asus Z87-Plus motherboard supports Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 MHz memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset provides maximum 6 USB 3.0 ports and maximum 6 SATA 6Gb/s ports for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset also supports iGPU function, letting users enjoy the latest Intel integrated graphic performance.
  • Fan Expert2 - customize Fan speeds
  • Digi+VRM - Precise Over Clocking
  • USB BIOS Flash Back - Easy Bios Updates
  • USB 3.0 Boost - Fast Data Transfer
  • EPU - Green Energy saving
  • New UEFI Bios Design.
ASUS Z87-PLUS - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600
USB / FireWire Ports
6 x USB 3.0 + (2 x USB 3.0 + 8 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 3000 MHz, 2600 MHz, 2666 MHz, 2500 MHz, 2933 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Intel I217V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x16 (x2 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 1 x DVI-D , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x Mini DisplayPort
Internal Interfaces
8 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, All-Solid Capacitor motherboard Design, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heatsink, USB 3.0 Boost, ASUS 8 Phase CPU Power Design, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Fan Xpert 2, ASUS Network iControl, ASUS USB Charger+, Intel Rapid Start Technology, Intel Smart Connect Technology, ASUS 2 Phase DRAM Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Remote GO!, DirectKey, Disk Unlocker, ASUS 5X PROTECTION, 4K Ultra HD ready, Intel Dynamic Storage Accelerator, Dual Intelligent Processors 4
I/O back plate
1 x SLI bridge , 3 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger+, ASUS AI Suite III
Plug and Play, RoHS, ErP Ready, ACPI 5.0
30.5 cm
23.37 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4*
Reviewed by Brian on 14/02/2014
The board itself is generally fine, the only issue is that you will need a USB 2 header to get your keyboard and mouse to work so you can actually install Windows. For some reason the USB 3 ports on the board won't recognise them outside of the BIOS. AT least that is what happened to me. AFter that it's plain sailing. Be warned, if you get a large heat-pipe fan like I did (Arctic i3) you can use your first RAM slot *facepalm*.
Scroll to top
