Click to visit BT.com
BT.com
Wishlist
Asus Z87-K S1150 Intel Z87 DDR3 ATX
Quicklinx: 8Q3PWS00
Mfr#: Z87-K
Essential accessories
The ASUS Z87-K supports Intel's new line of Haswell processors and features a PCIe 3.0 lane for the upcoming new graphics cards, making sure you will be future proof. On-board graphics now includes HDMI out as well as DVI and VGA for all your media needs. An exclusive feature to ASUS and found across our entire Z87 range is our fan headers. Our 4 pin headers provide PWM control for 3 pin fans, so you no longer need to upgrade your chassis fans and can save on an overall system build! We've also improved on our already well received UEFI BIOS, you can now track any changes you make automatically and we have included a quick note feature for overclocking. Simply type in anything you want to note down, gone are the days of using pen and paper when overclocking! Features
  • Fan Expert2 - customize Fan speeds
  • Digi+VRM - Precise Over Clocking
  • USB BIOS Flash Back - Easy Bios Updates
  • USB 3.0 Boost - Fast Data Transfer
  • EPU - Green Energy saving
ASUS Z87-K - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 2600 MHz, 2666 MHz, 2500 MHz, 2933 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111GR
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1 , 3 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x DVI , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 4 x USB 2.0 , 1 x PS/2 mouse
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, UEFI BIOS, SMBIOS 2.7 support, ACPI 4.0a support, DMI 2.7 support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, ASUS TurboV EVO, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, All-Solid Capacitor motherboard Design, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heatsink, USB 3.0 Boost, AMD Quad CrossFireX technology support, ASUS Fan Xpert 2, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS 5X PROTECTION, 4K Ultra HD ready, ASUS Enhanced DRAM Overcurrent Protection, Intel Dynamic Storage Accelerator
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger, ASUS AI Suite III
Plug and Play, ErP Ready, ACPI 4.0a
30.5 cm
20.8 cm
