BT.com
Wishlist
Asus Z170-PREMIUM Intel Z170 S1151 DDR4 PCIe U.2 M.2 USB3.1 ATX
Delivery
Standard Due date unavailable
ASUS Z170-Premium features unparalleled OC design and connectivity, with U.2 Thunderbolt 3 and 3x3 802.11ac Wi-Fi. Get performance, efficiency, digital power, fan control and even networking and audio tuning tailored for you. With 5-Way Optimization at your disposal it takes just one click to tune complex settings - for instant, highly controllable performance boosts! This exclusive technology dynamically optimizes essential aspects of your system based on real-time use, so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans and even networking and audio settings that are tailored for the apps you are using.
ASUS Z170-Premium - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600, 2 x SATA Express port, 1 x M.2, 1 x U.2 port
USB / FireWire Ports
2 x USB-C + 2 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
512 MB
Audio
Audio Codec
Realtek ALC1150
DTS Connect, High Definition Audio, DTS Studio Sound
LAN
Network Controller
Intel I219V / I211-AT
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 4 x PCIe x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2, 2 x SATA Express port, 1 x U.2 port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x DisplayPort , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 2 x USB 3.1 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 2 x USB 2.0 , 2 x USB-C , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x SPDIF out - header , 1 x Thunderbolt - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Clear Video HD Technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Wi-Fi GO!, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, DirectKey, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, Turbo LAN, ASUS Fan Xpert 3, Dual Intelligent Processors 5, LANGuard, USB 3.1 Boost, 16+4+2 Phase Power Design, ASUS Overvoltage Protection, ASUS Crystal Sound 3, ASUS PRO Clock Technology, ASUS 5X Protection II
ASUS NFC Express 2, wireless charger, ASUS 3T3R Wi-Fi moving aerials, I/O back cover, ASUS Hyper Kit, 2 x M.2 screws, Hyper M.2 x4 Mini card
6 x Serial ATA cable , 1 x SLI bridge , 1 x USB 3.0 cable , 1 x micro-USB to USB cable
Software Included
Drivers & Utilities, ASUS Auto Tuning, ASUS AI Charger+, ASUS AI Suite III, ASUS Turbo App, Mobo Connect, PC Cleaner, Media Streamer, HyStream, ASUS EZ Flash 3
Plug and Play
30.5 cm
24.4 cm
Scroll to top
