BT.com
Wishlist
Asus Xonar U5 5.1 Channel USB Soundcard and Headphone Amplifier
Delivery
Standard Due date unavailable
Compact 5.1-channel USB sound card and headphone amplifier with 192kHz/24-bit HD sound and Sonic Studio suite
  • True 5.1-channel HD (192kHz/24-bit) surround sound from a compact USB-powered device
  • 104dB signal-to-analog ratio (SNR) ensures pure sound
  • Sonic Studio provides complete control over loads of sound technologies
  • Perfect Voice technology eliminates noises for clear in-game communications
  • Independent mic and master-volume controls for instant in-game adjustments
  • Integrated headphone amplifier provides clear, detailed sound for an immersive audio experience
A compact audio solution for incredible sound
Xonar U5 is a compact 5.1-channel USB sound card designed to provide PC gamers with high quality audio for games, music and movies. It follows in the footsteps of the award-winning Xonar U7 - providing you with strong and clear sound via headphones, and producing more impactful and detailed audio than onboard hardware. The Xonar U5 has no standalone power supply and connects to your PC via USB, allowing you to instantly plug-in without having to open the PC case.
Take complete control of your audio with Sonic Studio
Xonar U5 features the latest Sonic Studio software suite, so you have full control over every audio setting ranging from equalization (EQ) to 5.1-speaker level-balancing. Sonic Studio has a single navigation page that puts everything in front of you, with an intuitive point-and-click interface that allows you to pre-set audio profiles to suit different audio requirements.
ASUS Xonar U5 - sound card
Sound card
Enclosure Type
External
Interface Type
USB
8 cm x 13.8 cm x 2.5 cm
Signal Processor
CM6631A
Sound Output Mode
5.1 channel surround
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
104 dB
Hardware Controls And Indicators
Volume control, output select
Apple MacOS X, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1, Windows 10 (32/64 bits)
Sound card
External
Interface Type
USB
8 cm
13.8 cm
2.5 cm
Processor / Memory
Signal Processor
CM6631A
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
104 dB
Frequency Response
10 - 44000 Hz
Headphone Amplifier, Perfect Voice
ASIO
1 x USB - 4 pin USB Type B , 1 x headphones - mini-phone stereo 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone stereo 3.5 mm , 1 x speakers (front surround) - mini-phone stereo 3.5 mm , 1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x audio line-in/microphone - mini-phone stereo 3.5 mm , 1 x SPDIF output - RCA
1 x S/PDIF optical adapter , 1 x USB cable
Software
Drivers & Utilities, Sonic Studio
Scroll to top
