BT.com
Wishlist
Asus Xonar DG 5.1 PCI Gamer Soundcard with Built-in Headphone Amp to Power Up Every Detail In Game
Asus Xonar DG 5.1 PCI Gamer...
£30.94
£30.94
Add to wishlist
Delivery
Standard Due date unavailable
Optimized for Immersive Gaming Action through Precision Audio
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with ASUS' own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
Built-in Headphone AMP
Powers up every sound detail in gaming
Xonar DG
3 headphone Amp gain modes for different usage scenarios
Xonar DG
VOIP mode
Specialized for VOIP headsets. Providing clear communication and music enjoyment.
Pro-gaming mode
Adding extra dynamics in higher frequencies for enhanced audio positioning.
Exciter mode
Immerse in the game with more powerful bass punch and fuller sound field.
Dolby® Headphone for an immersive 5.1 surround imaging
Xonar DG
GX2.5 for realistic 3D audio effects
Xonar DG
Automatic jack-sensing front-panel output Audio auto-switched from back to front with headphone plugged in!
Xonar DG
Output Signal-to-Noise Ratio (A-Weighted):
105 dB
Input Signal-to-Noise Ratio (A-Weighted):
103 dB
Output THD+N at 1kHz:
0.0025% (-92dB)
Input THD+N at 1kHz:
0.0022% (-93dB)
Frequency Response (-3dB, 24-bit/96kHz input):
<10Hz to 48kHz
Output/Input Full-Scale Voltage
1Vrms (3Vp-p)
PCI Bus Compatibility
PCI v2.2 or above bus compatible
Audio Processor:
C-Media CMI8786 High-Definition Sound Processor (Max. 96KHz/24bit)
24-bit D-A Converter of Digital Sources:
Cirrus Logic CS4245*1 (104dB DNR, Max. 192KHz/24bit) / Cirrus Logic CS4361*1 (103dB DNR, Max. 192KHz/24bit)
24-bit A-D Converter for Analog Inputs:
High Fidelity Headphone Amplifier:
Optimized for 32~150O
Analog Playback Sample Rate and Resolution:
44.1K/48K/96KHz @ 16/24bit for all channels
Analog Recording Sample Rate and Resolution:
S/PDIF Digital Output:
44.1K/48K/96KHz @ 16/24bit, Dolby Digital, DTS, WMA-Pro
ASIO 2.0 Driver Support:
Analog Output Jack:
3.50mm mini jack *3 (Front/Side/Center-Subwoofer)
Analog Input Jack:
3.50mm mini jack *1 (Line-In/Mic-In)
Other line-level analog input (for CD-IN/TV Tuner):
Aux-In (4-pin header on the card)
Digital S/PDIF Output:
High-bandwidth Optical Connector supports 96KHz/24bit - additional SPDIF-out header for HDMI audio output
Front-Panel Header:
Supports headphone jack-detection, automatically switch audio output from back-panel to front
Operation System:
Windows 7/Vista/XP/MCE2005
Dolby® Technologies:
Dolby Headphone: technology allows users to listen to music, watch movies, or play games with the dramatic 5.1-channel surround or realistic 3D spacious effects through any set of stereo headphones.
Smart Volume Normalizer™:
Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming
Xear 3D™ Virtual Speaker Shifter:
Adjustable virtual 7.1-speaker positioning
Magic Voice™:
Changes your voice pitch to different types (Monster/Cartoon…) for disguising your real voice or just for fun in online chatting
Karaoke Functions:
Music Pitch-Shifting, Vocal Cancellation, and Microphone Echo effects with Stereo Mix recording (Wave and Mic-in) for online Karaoke or online DJ applications
FlexBass™:
Professional Bass Management/Enhancement system
Other Effects:
10-band Equalier/27 Environment Effects
3D Sound Engines/APIs - Windows 7
DirectSound3D® GX 2.5, EAX®2.0&1.0, DirectSound® HW, DirectSound SW, A3D®1.0, OpenAL generic modes, 128 3D sounds processing capability
3D Sound Engines/APIs - Windows Vista
3D Sound Engines/APIs - Windows XP
DS3D GX2.5:
DS3D GX 2.5 supports EAX gaming sound effects and DirectSound 3D hardware enhanced functions on Windows 7/Vista. (DirectX/DirectSound 3D compatible)
Accessories
1 x Low-Profile Bracket, 1 x Driver CD, 1 x QuickStart Guide
Size (W x H)
64.39 x 170.44mm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* result!
Reviewed by Paul on 24/09/2012
great soundcard! very easy to install with software without any rubbish you dont need!
Great sound on the cheap works very well with budget headphones.
Scroll to top
