BT.com
Wishlist
Asus Xonar D2 7.1 PCI Ultimate Theatre & Gaming Soundcard 118Ddb SNR Provides Hi-Fi Class Audio
Asus Xonar D2 7.1 PCI Ultimate...
£112.44
£112.44
Add to wishlist
Delivery
Standard Due date unavailable
ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Center, which you will never have with onboard audio or other sound cards!
ASUS Xonar D2/PM - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI
Signal Processor
ASUS AV200
Sound Output Mode
7.1 channel surround
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
118 dB
Microsoft Windows XP, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista
Sound card
Internal
Interface Type
PCI
Processor / Memory
Signal Processor
ASUS AV200
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
118 dB
DirectSound, EAX 2.0, EAX 1.0, A3D 1.0, ASIO 2.0, Dolby Digital Live, DTS Connect, Dolby Pro Logic IIx, DTS Neo:PC, High Definition Audio
Audio Modes
Record: 24-bit 192 kHz , Playback: 24-bit 192 kHz
1 x audio line-out - mini-phone 3.5 mm , 1 x speakers (side surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (back surround) - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x SPDIF output - TOSLINK , 1 x SPDIF input - TOSLINK , 1 x MIDI - 4 pin MPC , 2 x audio line-in - 4 pin MPC , On supplied cable: 1 x MIDI - 5 PIN mini-DIN , On supplied cable: 1 x MIDI - 5 PIN mini-DIN
1 x audio (optical) adapter , 1 x audio (optical) cable , 1 x audio cable , 1 x MIDI adapter cable , 1 x MIDI panel
Software
Drivers & Utilities, CyberLink PowerDVD 7, Cakewalk SONAR LE, Ableton Live Lite, Cakewalk Project5 LE, Cakewalk Dimension LE
Additional Requirements
CD-ROM, adjacent PCI slot
System Requirements Details
1.4 GHz - RAM 256 MB - HD 60 MB
Asus Xonar D2 7.1 PCI Ultimate Theatre & Gaming...
£112.44
Save on this ideal PC Build kit!
Save £16.94
£137.82
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Sound!
Reviewed by niki on 31/03/2010
Asus sound cards really are amazing, and this one is no exception. Sound is great. Not quiet as good as the ST or STX, but still very good indeed. Finishing and presentation are absolutely superb. Despite what the previous reviewer said, I have had no trouble at all with the cards or drivers. They are rock solid.
5* Oh! And..
If you are considering this card for headphones; don't! Get the ST or STX instead. This card will happily drive headphones, but the ST and STX have a wider range of selectable output powers for different headphones. The card also sounds a little brighter and lighter than the ST and STX, which in my opinion is not as good for headphones.
5* Fantastic Sound
Reviewed by niki on 05/04/2010
Absolutely fantastic sound, and of the five PC's I have used these cards in, not one problem yet. One word of advice is that if you intend to use headphones, I would get the ST or STX because of the greater number of headphone impedance matchings. The quality of build and packaging leaves Creative for dead, frankly.
4* Fantastic when you get it going
Reviewed by Andy on 17/02/2011
This sound card replaced my old Audigy ZS 2 so as you can imagine it was a huge upgrade. DVD's MP3's Blu Ray all sound amazing.
I would have given it 5 out of 5 buyt I had issues installing the drivers. First it stalled on install, then it blue screened but as they say 3rd time lucky it worked.
It looks very stylish full of lights and the circle is also lighted. I do not understand these designs sometimes because when they are in the PC they always face down!?!?!?!
But if you are upgrading for home entertainment this is a no brainer!
You may have to explain to your neighbours why the walls are now shacking though!!! TURN IT UP TO 11
2* It's a problem!
Reviewed by Paul on 07/03/2010
This card makes a beautiful sound, combined with the 5.1 speaker system I bought at the same time ... sometimes. Unfortunately I've had repeated problems with it either making a horrible noise or none at all. I've had the card about 6 weeks, and I reckon a third of that time I've been struggling to get it to work. I've downloaded updated drivers and checked all the settings etc. I've probably uninstalled and reinstalled it 10 times. Because I've spent a lot of time just trying to get it to work I haven't really been able to explore its features or the software that comes with it. It's been difficult for me to figure out why, and support from ASUS has been limited. Unfortunately from postings on their customer forum that seems to be a common experience. I don't know whether there is a software or hardware problem, but I really want something to work out of the box and stay that way.
Scroll to top
