• Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Asus X54C-SX078V i3-2350 2.3GHz 6GB 320GB DVDSM 15.6" W7HP
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
The Perfect Fit for Work and Play
  • IceCool Technology keeps the palm rest area cool, placing heat-producing components away from users
  • Experience high transfer speeds with USB 3.0 10x faster than USB 2.0
  • Power4Gear automatically adjusts fan speeds for quiet computing and prolonged battery life
  • Palm Proof Technology disables the touchpad for uninterrupted typing and accuracy
Immersive Multimedia Experience
The ASUS X Series notebooks deliver an immersive multimedia experience through its high definition LED panel and Altec Lansing® speakers with SonicFocus software fine-tuning. Your ASUS X Series notebooks can also connect to HDMI-compatible TVs, consoles and entertainment systems.
IceCool Technology Keeps Your Hands Cool
Exclusive dual-sided motherboard design places hot components on the underside and away from users. Combined with heatpipes and vents, palm rests and typing surfaces stay cooler than the body temperature so they're cool even during the longest computing sessions.
Power4Gear with self-adjusting fan speeds
Power4Gear's self-adjusting fan helps you conserve battery power and provides for a more peaceful computing environment.
Go faster
Now included is USB 3.0 for up to ten times the speed of USB 2.0, so all your files and content can be handled and backed up expediently. Say goodbye to long frustrating waits, even a 25GB Blu-ray movie takes a mere 70 seconds to process.
Key features
  • Processor Intel® Core™ i3-2350M (2.3GHz)
  • OS Genuine Windows® 7 Home Premium 64bit
  • Display 15.6" HD (GL LED) (1366x768, Colour-Shine)
  • Graphic Card Integrated Intel® GMA HD
  • Storage 320GB (5400rpm) 2.5" SATA
  • Memory 4G (4096x1) + 2G On-board
  • Type DDR3 1333
  • ODD DVD Super Multi Dual Layer
  • Wireless 802.11 BGN
  • LAN 10/100/1000 Mbps
  • Webcam Yes
  • Battery Pack & Life 4 cell (2600mAh, 37 Whrs)
  • Warranty 1 year global
  • Keyboard Numeric
  • Card Reader 4 -in-1 card reader ( SD/ MS/MS Pro/ MMC)
  • Interface 1 x Microphone-in jack, 1 x Headphone-out jack (SPDIF), 1 x VGA port/Mini D-sub 15-pin for external monitor, 1 x USB 3.0 port, 1 x USB 2.0 port, 1 x RJ45 LAN Jack for LAN insert, 1 x HDMI
  • Audio Built-in speakers and microphone Altec Lansing® speakers
  • LED Status Indicator HDD, Power-on/Suspend, Capital Lock, Wireless on status indicator
  • Software ASUSDVD 6-in-1, ASUS Win flash for BIOS and Driver live Update, ASUS SmartLogon, ASUS Net 4 switch, ASUS Live Update, ASUS Multi-Frame, ASUS NB Probe +, ASUS Wireless Console, ASUS Data Security Management(ADSM), Virtual Camera, ASUS Splendid, ASUS Express Gate, ASUS Screen Saver, Fancy Start, eManual, AI Recovery
  • Dimension & weight 37.8 x 25.3 x 3.56 ~3.72 cm (WxDxH) 2.6 kg (with 4 cell battery)
  • Colour Black (Matte)
Scroll to top
