BT.com
Wishlist
Asus Wireless-N300 LTE 4G Modem Router
Delivery
Standard Due date unavailable
ASUS 4G-N12 is no ordinary Wi-Fi router. Just insert a 4G/LTE SIM card and its built-in modem connects to the internet wirelessly via super-fast mobile broadband. You can enjoy up to 100 Mbps downloads and 50 Mbps uploads, with no worries about USB dongle compatibility. And thanks to the wide coverage and 300 Mbps speed of 802.11n Wi-Fi, you can enjoy the 4G/LTE internet connection all around your home or office - perfect for those in locations where 4G/LTE speeds are faster than conventional ADSL or cable broadband. Convenient and cable-free, 4G-N12 will give you smoothly-streaming HD videos and fast file sharing anywhere. It can even connect to a cable modem to give a second internet connection for backup!
ASUS 4G-N12 - wireless router - WWAN - 802.11b/g/n - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Service Provider
Service not included
Cellular Protocol
UMTS, HSPA+, LTE, DC-HSPA+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
NTP, ICMP/IP, PPPoE, DHCP
Firewall protection, DMZ port, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, MAC address filtering, URL filtering, IP address filtering, event log, virtual server support, RADIUS support, Wi-Fi Protected Setup (WPS), static IP mode, UPnP Media Server, port triggering, dynamic IP mode, 802.1x authentication, ASUSWRT, keyword filtering
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP
17.45 cm x 12.5 cm x 2.95 cm
300 g
Wireless router - 4-port switch (integrated)
Service Provider
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
MPPE, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS
Status Indicators
Power, WAN, LAN, wireless, 3G, 4G
Communications
Wireless cellular modem
Cellular Protocol
Max Transfer Rate
100 Mbps
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 3 x 10Base-T/100Base-TX - RJ-45
Expansion Slots
1 (total) / 1 (free) x SIM
External power adapter
Enclosure Colour
2 x SIM card adapter
1 x network cable
17.45 cm
12.5 cm
2.95 cm
300 g
20 - 90% (non-condensing)
Scroll to top
