BT.com
Wishlist
Asus VX278H 27" 1920x1080 1ms DVI HDMI LED Gaming Monitor
Delivery
Standard Due date unavailable
Delicate touches make a monitor truly great, VX278H Full HD LED monitor, with extremely quick 1 ms response time, 80,000,000:1 high contrast ratio and HDMI interfaces, is optimized for the finest image and color quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
ASUS VX278H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
64.07 cm x 21.01 cm x 45.166 cm
Environmental Standards
ENERGY STAR Qualified
UL, BSMI, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, ErP Ready, TCO Displays 6.0, EAC
3 years warranty
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, aspect control
ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, Low Blue Light Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
64.07 cm x 21.01 cm x 45.166 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
2 x HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 64.07 cm - depth: 21.01 cm - height: 45.166 cm , Without stand - width: 64.07 cm - depth: 4.197 cm - height: 38.13 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Accessories
£8.41
£9.42
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.56
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£44.74
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.92
£60.32
Scroll to top
