BT.com
Wishlist
Asus VX229H 21.5" 1920x1080 5ms VGA HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
Inspired by millennia of artistic legacy, the VX229H sports an elegant and precision-crafted sundial design. The VX229H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It's ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
VX229H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency.
ASUS VX229H - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
27.9 kWh
Power Consumption (On mode)
19.1 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
49.98 cm x 21.01 cm x 37.13 cm
3.05 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL
3 years warranty
Display Type
Energy Class
Class A
27.9 kWh
19.1 W
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
Ultra Slim Design, HDCP, frameless, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Senseye+Photo Image Technology, ultra wide viewing angle, ASUS QuickFit Virtual Scale, ASUS GamePlus
49.98 cm x 21.01 cm x 37.13 cm - with stand
3.05 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
2 x HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x audio cable , 1 x VGA cable
Power Supply
Internal
26 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
£9.99
£7.22
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.34
£39.06
£52.90
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£60.02
Scroll to top
