BT.com
Wishlist
Asus VW199TL 19" 1440x900 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
It's easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
ASUS VW199TL - LED monitor - 19"
LED-backlit LCD monitor - 19"
Power Consumption (On mode)
13.1 W
Panel Type
TN
Native Resolution
1440 x 900
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
44.4 cm x 21.4 cm x 36.44 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, ISO 13406-2, WHQL, CB, CCC, PSB, EK, FCC, RoHS, ISO 9241-307, PSE Mark, GOST-R, J-MOSS, TCO Displays 5.2
3 years warranty
Display Type
13.1 W
Diagonal Size
19"
Viewable Size
19"
Panel Type
TN
Native Resolution
1440 x 900
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, sharpness, colour temperature
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut
44.4 cm x 21.4 cm x 36.44 cm - with stand
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Audio line-in , VGA , DVI-D
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
AC 120/230 V
27 Watt
Power Consumption Stand by / Sleep
0.2 Watt
0.16 Watt
Power Consumption Sleep
0.15 Watt
Dimensions & Weight Details
Without stand - width: 44.4 cm - depth: 29.57 cm - height: 6.46 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Scroll to top
