BT.com
Wishlist
Asus VT207N 19.5" 1600x900 5ms VGA DVI LED Touchscreen Monitor
Delivery
Standard Due date unavailable
Experience stunning visuals on this great touchscreen display with ASUS Smart Contrast Ratio and fast response time. Simply tap, drag, pinch, zoom or spin with your fingers for an amazingly natural and effortless touch experience.
What's in the box
  • ASUS VT207N
  • VGA cable
  • DVI cable
  • USB cable
ASUS VT207N - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5" - touchscreen
Power Consumption (On mode)
14.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
48.07 cm x 4.5 cm x 29.61 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, EAC, China Energy Label
Display Type
14.8 W
Diagonal Size
19.5"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Colour temperature
HDCP, Skin-Tone Selection, glare, ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, ASUS QuickFit Virtual Scale, 10-point multi-touch
48.07 cm x 4.5 cm x 29.61 cm - without stand
2.9 kg
Input
Touchscreen
VGA , DVI-D , USB 2.0 (Type B)
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
75 x 75 mm
1 x VGA cable , 1 x DVI cable , 1 x USB cable
Power Supply
Internal
16.4 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.14 Watt
Dimensions & Weight Details
With stand - width: 48.07 cm - depth: 19.99 cm - height: 36.116 cm
ENERGY STAR Certified
Scroll to top
