BT.com
Wishlist
Asus VS24AHL 24.1" 1920x1200 5ms VGA DVI HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
Delicate touches make a monitor truly great, VS24AHL 1920x1200 IPS LED monitor, with 16:10 aspect ratio, 80,000,000:1 high contrast ratio and HDMI interface, is optimized for fine image and color quality. The VS24AHL reaches a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
ASUS VS24AHL - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
25.1 kWh
Power Consumption (On mode)
17.2 W
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Screen Coating
Anti-glare
56.16 cm x 22.48 cm x 53.45 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, FCC, RoHS, WEEE, PSE Mark, J-MOSS, ErP Ready, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A+
25.1 kWh
17.2 W
Diagonal Size
24.1"
Viewable Size
24.1"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, input select, colour temperature, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
56.16 cm x 22.48 cm x 53.45 cm - with stand
6.1 kg
VGA , DVI-D , HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
160
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x HDMI cable
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Scroll to top
