BT.com
Wishlist
Asus VS247NR 23.6 inch Widescreen Full HD LED Monitor 3 yrs Warranty
Superior Image Quality Meets Classic Elegant Design
Delivery
Standard Due date unavailable
Delicate touches make a monitor truly great, VS247NR Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDCP support, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
True-to-life Pictures Powered by LED
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
Full HD 1080p Support 7 Aspect Control
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support When you would like to watch movies upward lying down, Smart View Technology can adjust color parameters to deliver the same image quality and colors with straight viewing. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
  1. Stylish and User-friendly Design for Modern Sophistication
  2. Convenient key controls for functional set-up in the multi-language OSD.
  3. Easily detachable base for wall mount. VESA Wall Mount Standard (100 x 100 mm ).
  4. 25° ( forward 5°, backwards 20° )Tilting Angle.
  5. KENSINGTON Security Lock.
SPECIFICATION
Display
  • Panel Size: Wide Screen 23.6"(59.9cm) 16:9
  • True Resolution : 1920x1080
  • Pixel Pitch : 0.272mm
  • Brightness(Max) : 250 cd/?
  • ASUS Smart Contrast Ratio (ASCR) : 50000000:1
  • Viewing Angle (CR?10) : 170°(H)/160°(V)
  • Response Time : 5ms
  • Display Colors : 16.7M
Video Feature
  • SPLENDID Video Intelligence Technology
  • SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
  • Skin-Tone Selection : 3 Modes
  • Color Temperature Selection : 4 Modes
  • HDCP support
Convenient Hotkey
  • SPLENDID Video Preset Mode Selection
  • Auto. Adjustment
  • Brightness Adjustment
  • Contrast Adjustment
I/O Ports
  • Signal Input : D-Sub, DVI-D
Signal Frequency
  • Analog Signal Frequency : 24~83 KHz(H)/ 50~75 Hz(V)
  • Digital Signal Frequency : 24~83 KHz(H)/ 50~75 Hz(V)
Power Consumption
  • Power ON: < 22.7W*
  • Power Saving Mode : < 0.5W
  • Power Off Mode : < 0.5W
  • Voltage : 100-240V, 50/60Hz
Mechanical Design
  • Chassis Colors : Black
  • Tilt : +20°~-5°
  • VESA Wall Mounting : 100x100mm
Security
  • Kensington lock
Regulation Approval
  • Energy Star®, BSMI, CB, CCC, CE, C-Tick, CU, EK,, ErP, FCC, J-MOSS, PSB, RoHS, UL/cUL, VCCI, WEEE, WHQL (Windows 7, Windows Vista)
Note
*Based on Energy Star 6.0 standard
ASUS VS247NR - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Power Consumption (On mode)
19.4 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
56.18 cm x 20 cm x 41.06 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, EK, FCC, RoHS, WEEE, J-MOSS, ErP Ready
3 years warranty
Display Type
19.4 W
Diagonal Size
23.6"
Viewable Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, input select, colour temperature, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology
56.18 cm x 20 cm x 41.06 cm - with stand
4.2 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
22.7 Watt
Power Consumption Stand by
0.28 Watt
Power Consumption Sleep
0.21 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Accessories
£8.41
£9.42
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.56
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£44.74
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.92
£60.32
Scroll to top
