BT.com
Wishlist
Asus VN247H 23.6" 1920x1080 1ms VGA HDMI LED Monitor
Delivery
Standard Due date unavailable
The ASUS VN series features compact dimensions- this 23.6" display has a super narrow bezel, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratchproof. The VN247H is also VESA wall mount compatible, and has the capabilities to be a stunning multi-screen solution.
ASUS VN247H - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
54.86 cm x 19.42 cm x 39.4 cm
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, TCO Displays 5.0, GOST-R, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
23.6"
Viewable Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature, aspect control
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
54.86 cm x 19.42 cm x 39.4 cm - with stand
3.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Microphone , Headphones , 2 x HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, anti-scratch
1 x VGA cable , 1 x audio cable , 1 x HDMI-DVI cable
22.7 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Scroll to top
