BT.com
Wishlist
Asus VE228TL 21.5" 1920x1080 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
Full HD 1080p Visual Enjoyment with Ergonomic design
VE228TL Full HD LED monitor reaches a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
True-to-life Pictures Powered by LED
  • Full HD 1080p for High-resolution Digital Content Display
  • 16:9 wide screen with 1920×1080 resolution is optimized for Full HD1080p vision and enables borderless full-screen video display.
  • Pristine and stunning image clarity.
  • Great for both video games and HD DVD movies playback.
Versatile position for personal visual comfort
It’s easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
Advanced Video Technologies for Exceptional Visuals
ASCR (ASUS Smart Contrast Ratio) Technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 80000000:1 – resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
User-friendly Design
  • Convenient key controls for functional set-up in the multi-language OSD.
  • Built-in hidden stereo speakers for multimedia enjoyment.
  • Easily detachable base for wall mount.
  • VESA Wall Mount Standard (100 x 100 mm ).
  • KENSINGTON Security Lock.
Complete After-Sale Service
  • 3-year system warranty
  • 3-year panel warranty
Green in Mind
  • Mercury-free LED-backlit panel
  • Corrugated cardboard packaging with at least 80% recycled content
  • Slim-flat packaging allows more cartons to be fitted per cargo, reducing transportation costs and CO2 emission
Energy and Planet Saving
  • 37.2k Wh electricity saving
  • 23.6kg reduction in CO2 emissions, equivalent to:
  • 1.9 trees planted
  • 2 years of oxygen for a family of four
ASUS VE228TL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
25.8 kWh
Power Consumption (On mode)
17.7 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
51.284 cm x 22.5 cm x 48.436 cm
5.94 kg
Environmental Standards
ENERGY STAR Qualified
UL, C-Tick, cUL, WHQL, CB, FCC, RoHS, ISO 9241-307, WEEE, J-MOSS, UkrSEPRO, TCO Displays 5.2, CEL level 2
3 years warranty
Display Type
Energy Class
Class A
25.8 kWh
17.7 W
Diagonal Size
21.5"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature, aspect control
HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode
51.284 cm x 22.5 cm x 48.436 cm - with stand
5.94 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , Audio line-in
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, tilt adjustment, swivel adjustment, adjustable height, pivot adjustment
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
Without stand - width: 51.284 cm - depth: 5.69 cm - height: 31.08 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Scroll to top
