BT.com
Wishlist
Asus VC279H 27" 1920x1080 5ms VGA DVI HDMI IPS Monitor
27", Slim Bezel, IPS Monitor
Delivery
Standard Due date unavailable
VC279 series feature with In-Plane Switching technology panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. The VividPixel Technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience.
ASUS VC279H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
62.26 cm x 20 cm x 44.2 cm
4.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1
3 years warranty
Display Type
Energy Class
Class A+
31 kWh
21 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, colour temperature
HDCP, frameless, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology
62.26 cm x 20 cm x 44.2 cm - with stand
4.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
DVI-D , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable
Power Supply
External
AC 120/230 V (50 - 60 Hz)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 62.26 cm - depth: 4.65 cm - height: 37.26 cm , With stand - width: 62.26 cm - depth: 20 cm - height: 44.2 cm - weight: 4.4 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Scroll to top
