Click to visit BT.com
BT.com
Wishlist
Asus U3S6 USB 3.0 / SATA 600 PCI-e Card, ultra-fast data transfers at 4.8Gbps with USB 3.0
Quicklinx: 6L6TWS00
Mfr#: U3S6
Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gbps data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components.
ASUS U3S6 - storage / USB3.0 controller - SATA 6Gb/s - PCIe 2.0 x4
Storage / USB3.0 controller - plug-in card
Bus Type
PCIe 2.0 x4
SATA 6Gb/s
Supported Devices
Hard drive
Channel Qty
2
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista
12.2 cm x 7.6 cm
ASUS M4A77TD, M4A77TD PRO/U3S6, M4A785TD-V, M4A785TD-V EVO/U3S6, M4A79T, M4A79T Deluxe/U3S6, Maximus III Formula, P6T, P6T6, P6T7, P6TD, P7P55, P7P55D, Rampage II Extreme, Rampage II Extreme Republic of Gamers, Rampage II GENE Republic of Gamers
Host Bus
PCIe 2.0 x4
Storage Controller
SATA 6Gb/s
Supported Devices
Hard drive
Channel Qty
2
2 x USB 3.0
Compatible Slots
1 x PCI Express 2.0 x4
2 x Serial ATA cable
Software Included
Drivers & Utilities
12.2 cm
7.6 cm
ASUS M4A77TD PRO, M4A77TD PRO/U3S6, M4A785TD-V EVO, M4A785TD-V EVO/U3S6, M4A79T Deluxe, M4A79T Deluxe/U3S6, Maximus III Formula, P6T, P6T Deluxe, P6T SE, P6T WS Professional, P6T6 WS Revolution, P6T7 WS SuperComputer, P6TD Deluxe, P7P55 LX, P7P55 WS SuperComputer, P7P55D, P7P55D Deluxe, P7P55D Evo, P7P55D LE, P7P55D PRO, Rampage II Extreme, Rampage II Extreme Republic of Gamers, Rampage II GENE Republic of Gamers
